Can i install and use component one inside windows container?
Posted by: elakkya.m on 18 November 2019, 4:58 am EST
    Posted 18 November 2019, 4:58 am EST
    I want to install componentone and use it inside container, i am copying .exe file and trying to run it simply but it doesnt work.I googled to find out any command to silently install, then i came up across this bloghttps://www.grapecity.com/blogs/how-to-silently-install-and-activate-c1-net-controls the command it ask me to run is “path\C1LicenseActivation.exe” /as:serialkey /u:name /c:company, burt currently i seek to use trial version and if i succeed then only i require to buy , and the command requires license
  • Posted 18 November 2019, 6:58 am EST
    Thank you for evaluating ComponentOne product.
    The command you mention is for activating the product silently. And since you’re currently on trial, you would not need to activate the product.
    To silently install ComponentOne, you should use the command installerexe -i -s -p"productcode1,productcode2".
    Ruchir
