Posted 7 January 2022, 7:15 am EST
it will be helpful if Could someone can provide code for cascading in flex grid like when we select country then state should be selected in angular 10
Forums Home / ComponentOne / General Discussion
Posted by: akp80417 on 7 January 2022, 7:15 am EST
Posted 11 January 2022, 5:31 am EST
As per our understanding, you want to dynamically update values in a column based on the value selection of another column. If so then you may use the DataMap and update the getDisplayValues method as per the logic. Please refer to the wijmo demo link below demonstrating the same:
https://www.grapecity.com/wijmo/demos/Grid/Columns/DynamicDataMaps/purejs
In the above sample, changing the cell value in country column will update the cities dropdown list in the city column.
