Component One Studio Enterprise
Posted by: morourke on 27 November 2017, 10:13 am EST
    Posted 27 November 2017, 10:13 am EST
    I have been trying to install the purchased license key for the Studio Enterprise Edition.
    However, I seem to be doing something wrong and some of the options on the forums, like telling me to browse to a CS1Setup folder do not work.
    One of the forum posts indicated that it is necessary to download CS1StudioInstaller20163.14 However, this is some 708,415Kb and seems a bit large to simply be a license installer. Is this another version of the Component One Studio Enterprise application, and if so how is it different from the file downloaded from Component Source (re-seller)?
    Michael O’Rourke
  • Posted 27 November 2017, 10:15 am EST
    Regarding the above there is no C:|Program Files (x86)| ComponentOne| C1StartMenu folder installed??
    Michael O’Rourke
  • Posted 28 November 2017, 2:34 am EST
    The download related to CS1StudioInstaller20163.14 is version specific. The one that you would have downloaded recently from the re-seller website would allow you to download the latest version. To be clear about the file that you have downloaded, we would request you to share the version mentioned with it, if any or the name/type of the file.
    Kindly run the setup with the file downloaded from Component Source. Once ComponentOne is successfully installed on your machine, you would be able to see the C1StartMenu directory at the location: C:\Program Files (x86)\ComponentOne.
    Now, you may activate the license on your machine using the license key provided to you, by following the below mentioned steps:
    1. Open a File Explorer window and navigate to your Local Disk (C:) drive.
    2. Go to “Local Disk (C:)/Program Files(x86)/ComponentOne/C1StartMenu/Activation” file location and click on ComponentOne License Activation.
    3. Enter User name, Company and Serial Number and follow the steps for Activation in the window.
      This will activate ComponentOne Studio on your machine.
    Let us know if you need further assistance.
