Conversion From C1Reports to FlexReports Open previous reports
Posted by: Matthew.Peitz on 24 February 2021, 12:05 pm EST
    Posted 24 February 2021, 12:05 pm EST
    We are converting from C1Reports to FlexReports. We have several reports that we have saved off as C1PrintDocuments in C1Zip files. Is there a way to open c1Printdocuments with C1flexReports?
  • Posted 25 February 2021, 12:32 am EST
    C1FlexReport does not contain C1PrintDocument and related assemblies. Thus, This is not possible to open C1PrintDocument with C1FlexReport.
    However, you can convert your C1Report to C1FlexReport.
    Please check the below link for the same.
    https://www.grapecity.com/blogs/3-ways-to-convert-your-c1report-to-flexreport
  • Posted 25 February 2021, 9:16 am EST
    We have reports that are snap shots and already generated with data (hence the c1 print document). That doesn’t seem to work with conversion link you sent.
  • Posted 1 March 2021, 8:46 am EST
    Sorry to say but this is not possible to use C1PrintDocument with C1FlexReport.
    However, you can use a workaround like:
    1. First create images from C1PrintDocument using Screenshots or any other tool
    2. Now, you can use these images in C1FlexReport using Image Field.
    Hope, this will help you.
