Cursor movement not showing up in Frozen Columns
Posted by: aaitha on 20 September 2017, 12:44 pm EST
    Posted 20 September 2017, 12:44 pm EST
    Hi Team,
    I have frozen columns in the Flex Grid, where
    fg.Cols.Frozen is used.
    The issue here is, we are not able to see the cursor movement, we are not able to select, though it should not be editable, we want the cursor to be shown when selected. We have used the frozen property as we want some columns to be frozen.
    Please suggest as it is urgent.
    Amar.
  • Posted 22 September 2017, 2:47 am EST
    Hi Amar,
    I am sorry to mention but I could not replicate the issue at my end. Please refer the attached sample.
    Could you please either modify the attached application or provide your own stripped down project so that I can try reproducing the same behavior at my end and assist you further accordingly?
    You may also try using the latest build and see if the problem persists. You can download the same from here:
    http://prerelease.componentone.com/dotnet40/c1winforms/2017-t2/C1WinForms.4_4.0.20172.271.zip
    Pragati
    FlexGrid.zip
  • Posted 3 October 2017, 2:16 pm EST
    Hi Pragati
    Thank you for your reply.
    In the same you have provided. The issue is reproduced. When I click on the two columns Dosage and Drug, cells are not selected. Though they are frozen, we want the select option on these cells.
    I should be in a position to select the cell and also move up or down with the key board. This happens correctly on the other two cells which are not frozen. Patient and Date column are working fine, Same behavior I want on the frozen columns Dosage and Drug.
    This is my requirement though first two columns are frozen.
    thanks,
    Amar.
  • Posted 4 October 2017, 4:19 am EST
    I am able to select the cell select the cell and also move up or down with the key board at my end. Please refer the attached video for demonstrating the same.
    Could you please try using the latest build and see if the problem persists. You can download the same from here:
    ThanksFlexGrid_Frozen_Issue.zip
  • Posted 4 October 2017, 2:39 pm EST
    Hi Mohit,
    Thanks for your reply.
    Now it is working fine after upgrading to the latest version.
    Can you please suggest, what is the best way to upgrade the project completely.
    We are already in production, so just wanted to make sure how it is going to impact and what is the best practice to upgrade the project to the new version.
    Amar.
  • Posted 5 October 2017, 2:20 am EST
    You could use the C1ProjectUpdater to update your project.
    C:\Program Files (x86)\ComponentOne\C1StartMenu\C1ProjectUpdater
    Then choose your solution.
    This will automatically set the References in your project to Version Specific = false
    Then will update your licenses.licx to not be version specific
    Then it will update your controls to the new version.
    You will also be able to do this manually if you would like to.
  • Posted 5 October 2017, 2:30 pm EST
    Hi Mohit,
    Now, I just got an update, that I cannot do a version upgrade at this point of time, as we have some planned work going on.
    For now, Alternative is to fix the problem in the Version “C1WinForms.4_4.0.20171” without upgrading. Do you have any suggestion for me to do the fix without doing the Component One Upgrade?
    Old versions never had this issue, is it introduced as bug in “C1WinForms.4_4.0.20171”. Because old versions we have are working fine.
    amar
  • Posted 6 October 2017, 12:29 am EST
    You could use hotfix of version “C1WinForms.4_4.0.20171” instead of upgrading . Issue is also fixed in hotfix of “C1WinForms.4_4.0.20171” which can be downloaded from below links.
    http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms.2_2.0.20171.261.zip
    http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms.4_4.0.20171.261.zip
    Hope it helps.
