FlexReport High DPI Monitor
Posted by: marcel on 15 May 2020, 11:37 am EST
  • Posted 15 May 2020, 11:37 am EST - Updated 4 October 2022, 7:51 am EST
    When rendering a report on a monitor with a high dpi, if I set the Windows video scale to 200%, the RTF field is rendered with the wrong size.
    I tried also to use Superlabel field. But even when I setted the RTF property to true, the text not rendered with a RTF Formatted text. `
  • Posted 19 May 2020, 3:03 am EST
    Hi Marcel,
    RtfField is used to show the RTF content in the FlexReport so you should use it to fulfill your requirement.
    I have attached a Report which shows the RTF content in a RtfField successfully in higher and the normal DPI, please have a look.
    RTF.zip
  • Posted 19 May 2020, 11:38 am EST - Updated 4 October 2022, 7:51 am EST
    Hi…
    In yours 200% picture I only see the text in RTF field. Can’t see the report title for comparing.
    I’m opened your test in C1FlexReportDesigner and clicked in preview button in my Surface PRO 7. See the results in attachment. Do you have any idea how to solve this?
    100%:
    200%:
  • Posted 21 May 2020, 7:19 am EST
    Hi Marcel,
    Sorry, but we cannot replicate the issue at our end with higher DPI, and here are the screenshots attached with the report title which shows that it is showing correctly.
    The environment details at our end are:
    Win 10 version 1903
    Control Version 4.0.20201.416
    To further investigate this issue we need your environment details so that we can assist you accordingly.
    RTF Images.zip
  • Posted 23 May 2020, 9:57 am EST
    Hi…
    same versions here.
    Best regards,
    Marcel Souza
  • Posted 27 May 2020, 7:43 am EST
    Hi Marcel,
    As we do not face the issue at our end and understand your concern so we have requested the concerned team to arrange a remote session to get the issue solved at your end ASAP. The team will get in touch with you soon.
