Grid Merge Function
Posted by: duwhd791 on 14 November 2021, 9:45 pm EST
    Posted 14 November 2021, 9:45 pm EST
    Hello, I have a question about the grid merge function.
    For Row as integer = grid.Rows.Fixed To grid.Rows.Count - 1
    Dim flag As Integer = grid.GetData(Row, “flag”)
    Select Case flag
    Case 1
    range = grid.GetCellRange(Row, 2, Row, 7)
    grid.MergedRanges.Add(range)
    range = grid.GetCellRange(Row, 9, Row, 15)
    If the source is coded in that way, the merge part is correct when inquiring the data for the first time.
    However, if the next data is inquired, the current grid merge is applied in addition to the previous grid merge, and the merge values are mixed and inquired.
    Is there a way to initialize the merge value every time it is inquired?
  • Posted 15 November 2021, 1:15 am EST
    You can clear the merge value every time the data is inquired by using the grid.MergedRanges.Clear() method and then create the merging again for the new data inquired.
    We have attached a sample to show the same.
    Please let us know if you need any other information.
    Avnish
    CellMergeDemo.zip
  • Posted 15 November 2021, 3:16 am EST
    Thank you, Avnish.
    I’ve been looking for this code for a long time.
    I checked that it’s working normally.
    Thank you so much!
    YJ
