How to Disable the cells
Posted by: sdayal on 8 February 2023, 12:50 am EST
    Posted 8 February 2023, 12:50 am EST
    Hi wijmo team,
    https://stackblitz.com/edit/angular-hfym2t?file=src%2Fapp%2Fapp.component.html
    In above snippet I want to disable the full name and short name cells for all the existing entries but not for newly added. How can I do that?
  • Posted 9 February 2023, 8:47 pm EST
    This can be done by adding wj-state-disabled class to the cells which are already present in the CollectionView. You may get the recently added data from the itemsAdded property of the CollectionView but, for that you have to add the new item using the addNew() method of CollectionView since, trackChanges will keep the record of newly added items only if proper CollectionView methods are used to add the item. Also, you may handle beginningEdit event of FlexGrid and can cancel the event if the cell contains “wj-state-disabled” class.
    Please refer to the updated sample for reference: https://stackblitz.com/edit/angular-osd2my?file=src%2Fapp%2Fapp.component.ts,src%2Fstyles.css
    Manish Gupta
  • Posted 10 February 2023, 1:37 am EST
    Thank you! It worked!!!
