Installation problems on Windows Vista
Posted by: soestp on 10 September 2017, 12:22 pm EST
  • Posted 10 September 2017, 12:22 pm EST
    I've had problems installing C1StudioNET2_T306.msi on Windows Vista. BecauseI couldn't uninstall, I installed C1StudioNET2_T108_Setup.msi with the hope this one would be more succesful on Windows Vista. However, this installation gave an error too. Again an uninstall fails with the message that the uninstallation couldn't be finished since the installation failed. When I do a repair (which is initiated by running one of the installer packages) I got a message that the installation is succesful.
    So is there a patch for these installers? At least I want to get rid of the C1StudioNET2_T108 installation since our software uses C1StudioNET2_T306.
    I've admin rights and I switched UAC. During the initial installation I had VS 2008 installed only. Later on, I've installed VS 2005 too.
    Who can help?
    cheers,
    Peter
    Hi Peter,
    Once you've completed the install using the repair, the uninstall should work.
    If not, you can reinstall the T2-2006 version over the current 2008 version. It should replace all of the files in your bin directory which would be the equivalent of uninstalling and reinstalling.
    Thanks!
  • Posted 2 November 2021, 7:37 am EST
    First of all, Make sure you software is compatible with the windows version you are using.
    for that you can.
    • Click Start, and then click Control Panel.
    • Click Programs, and then under Programs and Features click Run programs made for previous versions of Windows .
      The Program Compatibility Troubleshooter opens.
    • Click Next to start the wizard.
    • The troubleshooter detects any issues with older programs.
    • Scroll through the list of software programs, select the software title you want, and then click Next.
    • Select Try recommended settings.
    • Click Start the program to test the program with the new settings.
    • Click Next and do one of the following actions depending on what happens
    • If the software opens and can be used, you are done. Click Yes, save these settings for this program.
    • If the software still fails, click No, try again using different settings.
    Try to do this.
  • Posted 4 March 2022, 5:38 am EST
    Fix Windows installation error by following this steps-
    -Make sure that your device has enough space.
    -Run Windows Update a few times.
    -Check third-party drivers and download any updates.
    -Unplug extra hardware.
    -Check Device Manager for errors.
    -Remove third-party security software.
    -Repair hard-drive errors.
    -Do a clean restart into Windows.
    Rachel Gomez
