Posted 28 June 2019, 1:04 pm EST
- Updated 4 October 2022, 8:01 am EST
First of all, this is a new computer and the only C1 components that I’ve loaded are the latest ones. Hovering in the Toolbox indicates the latest version.
I have followed you suggestions. First I changed the Specific Version to false, and removed the version and toke information from the license file. Then I removed the old SuperTooltip from the form and tried to add a new one from the toolbox and i get the error in the attachment called Err1.
So then I started over, but this time I removed the entire license file and when I try to remove the tooltip control I get the error in the attachment Err2.
So I started over again, removed the license, removed the control, removed the reference and this time was able to add the new control, but I get compile time errors as in the attachment Err3.
So, I don’t know how you got it to work, as I said I’m using VS2019 maybe there is an incompatibility with it. So I tried to create an entirely new program, just a button, SuperTooltip control and 3 lines of code in the Button MouseHover and I got the same errors as in Err3. In otherwords, I have the same problem creating an newapplication as trying to convert an old one.
This makes me think that there is an incompatibility with VS2019, or a problem VS or C1 was installed. Or is there something specific about SuperToolTip that I’m missing
You are welcome to do a remote log in here and try it yourself, but as of now I have no solution. This does not work.
