Installing Component One Enterprise Studio 2006
Posted by: gerald.eckert on 17 March 2020, 11:01 am EST
    Posted 17 March 2020, 11:01 am EST
    I am trying to Install ComponentOne Studio for .NET 2.0, Enterprise Studio 2006.
    I get this error ```
    “The wizard was interrupted before ComponentOne Studio for .NET 2.0 could be completely installed”.
    The first error in the install logs looks like its failing on
    MSI (c) (F0:BC) [10:27:46:489]: Doing action: C1CallLicense
    Action 10:27:46: C1CallLicense.
    Action start 10:27:46: C1CallLicense.
    MSI (c) (F0:BC) [10:27:46:489]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT
    Action
    Type
    Source
    Target
    , NULL,
    ExtendedType
    FROM
    CustomAction
    WHERE
    Action
    = ‘C1CallLicense’
    MSI (c) (F0:98) [10:27:46:490]: Invoking remote custom action. DLL: C:\Users\GECKER~1.WIN\AppData\Local\Temp\MSI5D82.tmp, Entrypoint: Install
    MSI (c) (F0:BC) [10:27:46:503]: Note: 1: 2727 2:
    Action ended 10:27:46: C1CallLicense. Return value 3.
    DEBUG: Error 2896: Executing action C1CallLicense failed.
    Internal Error 2896. C1CallLicense
    Action ended 10:27:46: InstallWelcome. Return value 3.
    Windows 8.1 Pro 64 Bit
    Attached is the Install log and some of my notes.[zip filename="C1 Forum Help.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-22929ba9-3edd-424f-9d6a-4ed8385c144e.zip[/zip]
  • Posted 18 March 2020, 5:11 am EST
    As you are using a very old version of ComponentOne i.e. 2006 and it is not tested with the latest Windows versions including Windows 8.1 that you are using so it is likely that it will not work.
    As there have been many changes done over the years so I would suggest you kindly upgrade to the latest version which will work properly with Windows 8.1 Pro.
    You can download the latest version from the given link:
    https://www.grapecity.com/download/componentone
  • Posted 18 March 2020, 6:27 am EST
    Hello Prabhat,
    Thank you for your response. Unfortunately my software requires that version of the software.
    Do the install logs indicate any type of problem that I might be able to fix?
    What does the function
    C1CallLicense
    do during the Install and what about the return code of 3? ```
    -G
  • Posted 19 March 2020, 3:26 am EST
    Sorry, but this much old version is not supported with Windows 8.1 pro so I would suggest you use the older Windows version which is compatible to work with this.
