License file
Posted by: mayur.purandare on 24 December 2019, 12:02 am EST
    Posted 24 December 2019, 12:02 am EST
    Where can I find license.txt available for the component One. I did not find it on website except EULA available on site.
  • Posted 24 December 2019, 4:50 am EST
    It seems that you are looking for the licenses.licx file. The file is specific to your application and contains entries related to the C1 controls you use in the same. To generate a licenses.licx file corresponding to your application, you can use the LicxGenerator tool. Learn more about the same from here: https://www.grapecity.com/blogs/licensing-and-licenses-licx-file-licxgenerator-tool/.
    You can also generate it by dragging and dropping the related controls in your application. The file with the required entries will be generated. You can then delete the controls added, in case your final application has the controls added to it at run-time.
  • Posted 26 December 2019, 5:23 am EST
    We do not want licenses.licx file as we already have it.
    Like we have Licence.txt file for MVVM light, Please check file on below link.
    https://github.com/lbugnion/mvvmlight/blob/master/GalaSoft.MvvmLight/GalaSoft.MvvmLight%20(PCL)/License.txt
    Similar type of file we need for Component One.
    Kindly do needful.
  • Posted 27 December 2019, 1:22 am EST
    We do not have any ready-to-use license.txt file. However, you can copy the required GrapeCity based Copyright information from the EULA and use it in your application in a file that you create yourself.
