Posted 5 September 2019, 4:02 pm EST
Loading an XML file in Web Grid control of C1
Posted by: Victor.m.charles.civ on 5 September 2019, 4:02 pm EST
Posted 6 September 2019, 4:37 pm EST
Hello Alec,
Thank you for your message, I look forward to hear from you Monday. Also is it possible to have all three Grid controls display like list boxes instead of a dropdown control?
Kind regards,
Victor
Posted 7 September 2019, 2:21 pm EST
Alec,
Below is the code used to select all or clear data in the top two Grids, if possible to display the FlexGrid like is list box control, is the same possible with FlexGrid version? I have other capabilities in C1TrueDBGrid would like to convert to FlexGrid, but probably best to wait until case is closed…
private void radioButton5_CheckedChanged(object sender, EventArgs e)
int i = 0;
int count = this.C1TrueDBGrid1.Splits[0].Rows.Count;
this.C1TrueDBGrid1.SelectedRows.Clear();
for (i = 0; i < count; i++)
this.C1TrueDBGrid1.SelectedRows.Add(i);
}} private void radioButton6_CheckedChanged(object sender, EventArgs e) { this.C1TrueDBGrid1.SelectedRows.Clear(); radioButton10.Focus(); }
Victor
Posted 9 September 2019, 5:57 am EST
Hello Victor,
The MVC Application works differently from Windows application. It has two side Client Side and ServerSide.The MVC Edition control of ComponentOne can’t be accessed at ServerSide. The data can be provided using the callback from Client to server.
Also, the FlexGrid required the data in Array of JSON/objects format, it does not accepts directly XML or DataTable.
It required to conversion the data to array of JSON/objects to show in FlexGrid.For showing, FlexGrid same as ListBox, if we are correct, you are looking for the implementation same as follows demo:
https://www.grapecity.com/wijmo/demos/Grid/Selection/CheckboxSelection/purejsRegards,
Manish Gupta -
Posted 9 September 2019, 11:22 pm EST
Hello Manish,
I mainly need to use checkbox control, but will also need to use the FlexGrid for other features in the application.
Is it possible to send me a sample project with a solution for both controls using JSON/objects?
Kind regards,
Victor
Posted 10 September 2019, 2:52 am EST
Hi Victor,
In MVC, C1 does not have any control for Checkbox. We uses standard CheckBox through out the application.Please find the attached sample for reference.
Manish Gupta -
Posted 11 September 2019, 3:24 pm EST
When trying to run your sample project, I am receiving error message.
LicenseException: A valid license cannot be granted for the type C1.Web.Mvc.LicenseDetector. Contact the manufacturer of the component for more information.
On block of code beloe:
@(Html.C1().FlexGrid().Id(“grid”).AutoGenerateColumns(false)
.Bind(m => m.Bind(Model).DisableServerRead(false))
.Columns(c =>
c.Add().Binding(“Active”).AllowSorting(false).AllowDragging(false).AllowMerging(false);
c.Add().Binding(“Last”);
c.Add().Binding(“First”);
c.Add().Binding(“Sales”);
.ItemFormatter(“ItemFormatter”)
.Height(500)How do I fix this error?
Victor:
Posted 12 September 2019, 3:28 am EST
Hi Victor,
This might be because of the version used by C1.Web.Mvc control is compatible with C1 serial key activated on your machine.
For e.g the shared sample used the latest build version <4.0.20192.225> which will be compatible with the Studio Enterprises or Studio Ultimate serial key purchased in 2018v2 version or after.
Please create a SupportOne ticket for discussing the Licensing Issue:
http://supportone.componentone.com/homeRegards,
Manish Gupta
