Missing assembly "C1.Win.C1Themes.4.dll" for "C1ReportDesigner.exe"
Posted by: schmitt.alexander on 21 February 2018, 8:12 am EST
    Posted 21 February 2018, 8:12 am EST
    I want to use the C1ReportDesigner for one of our projects. And we are looking for some options like Autosave, etc…
    To do so I started the following application:
    C:\Program Files (x86)\ComponentOne\C1Reports\v4\C1ReportDesigner.exe
    When I expected to see the option dialog, a exception was raised, which stated, that the assembly “C1.Win.C1Themes.4.dll” is missing. (See screenshot)
    The same exception raises for the Grid-Properties.
    I downloaded the current trial version and older version. In all version this assembly is missing.
    Can you please provide me this assembly for the full functionality of the C1ReportDesigner?
    Exception.zip
  • Posted 21 February 2018, 9:37 am EST
    I thing there is some thing wrong with your machine.
    Please try with the below suggestions:
    1. Download the ComponentOne Cleanup utility to clean the previous installation of ComponentOne Studio from the below link and run:
      http://cdn.componentone.com/files/c1cleaner/ComponentOneCleaner20161.1.5.exe
    2. After completion of the step 1 download the latest ComponentOne Studio from:
      https://www.grapecity.com/en/download/componentone-studio
    3. Install the ComponentOne Studio
    4. Run the C1ReportDesigner from
      C:\Program Files (x86)\ComponentOne\Apps\v4.0\C1ReportDesigner.exe
    Hope, this will solve your issue.
    Singh
  • Posted 22 February 2018, 5:28 am EST
    Hi Singh,
    Thank you for your support.
    1.) I download the Cleaner Tool and executed it. But I got an error (see bleow)
    2.) I tried to install the ComponentOne Studio on another machine and the installation was interrupted by an errror (see Screenshot below). Maybe this will be a result of our company policies. (Screenshot)
    3.) So I tried an older offline installer I found on your ftp site (but newer than our registered version)* “ftp://ftp.componentone.com/SupportFTP/C1Installers/
    and after the installation the needed file was still missing in the concerning directory. (See screenshot below on german Windows)
    Can you please double-check if this file is really delivered with your installer?
    Alex
  • Posted 22 February 2018, 7:04 am EST
    Hi schmitt.alexander,
    Please share the below log files of C1StudiosWebInstaller and ComponentOneCleaner utility which is generated in documents folder on which the error is raised at the time of installation/running.
    1. C1StudiosWebInstaller.log
    2. ComponentOneCleaner.log
    So that we can assist you accordingly.
    Singh
  • Posted 22 February 2018, 8:11 am EST
    Hi Singh,
    Thank you for your quick response. You find the files in the attachment.
    Best regards,
    Alex
    C1Logfiles.zip
  • Posted 23 February 2018, 5:16 am EST
    Hi Alex,
    This has been answered in the SupportOne case 310357. Please continue the thread over there.
    Note: You can login into SupportOne using the same credentials as over the forums:
    https://supportone.componentone.com/
    Pragati
  • Posted 23 February 2018, 9:24 am EST
    Now I was able to install the new trial version an the missing dll is there for 2017 version of ComponentOne C1ReportDesigner. In elder versions (including the 2016) this .dll I have not found. But for now I’m pleased and want to thank you again.
    Best regards,
    Alex
  • Posted 16 March 2018, 3:19 am EST
  • Posted 16 March 2018, 3:23 am EST
