Plus parameter and page
Posted by: thinh.dao-dang on 14 June 2019, 3:04 am EST
    Posted 14 June 2019, 3:04 am EST
    hi. i’m Thinh and i from VietNam, please answer me a question.
    when i get a parameter from preview sourcecode, so after
    i plus [page] with [prmPage]. but it not show anything
    rptSub1.Parameters[“prmPage”].Value = 10;
    rptSub1.Parameters[“prmTotalPage”].Value = 10;
    "Page " & [Page + CInt(prmPage)] & " / " & [Pages + CInt(prmTotalPage)]
    what can i do?
  • Posted 17 June 2019, 2:24 am EST
    Assuming that you are using C1FlexReport, please inform about the use-case based on which you intend to use parameters for displaying page numbers.
    The below mentioned code can be used to set calculated page numbers in a TextField, at run-time:
    TextField tf = new TextField();
    tf = (TextField)c1FlexReport1.Fields[“ftrRight”];
    tf.Text.Expression= “"Page " & [Page] & " / " & [Pages]”;
    Further, values of parameters used in a report can be fetched as follows:
        c1FlexReport1.Parameters[0].Value = 10;
                Console.WriteLine(c1FlexReport1.Parameters[0].Value);
    Once a report has finished rendering, you can fetch the pages, as follows:
    private void c1FlexReport1_EndReport(object sender, EventArgs e)
    Console.WriteLine(c1FlexReport1.PageCount);
    Refer the attached application for the implementation.
    In case it does not help, please elaborate on the requirement so that I can assist you further.
    [zip filename="prj_FlexReport.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-67d70a27-1540-4a49-9268-b86ee6efa6c8.zip[/zip]
  • Posted 17 June 2019, 8:46 am EST
    once more question,
    how to get Pages in previewSheet.cs ( function setData() )
  • Posted 18 June 2019, 12:14 am EST
    Hi esha.dhir, thanks for support me.
    i did as follow, but i can’t get anything
    int pageDefaut = 10; // parameter
    tf.Text.Expression= “"Page " & pageDefaut + [Page] & " / " & pageDefaut + [Pages]”;
    becasue, i have 2 report, the first, report 1 print, and get pages of report 1,
    after, report 2 print with begin pages of report 1
    ex: report1 result page 10,
    => report 2 = 10 + page of now / 10 + pages of now.
    please help me, what can i do?
  • Posted 19 June 2019, 1:09 am EST
    This expression is not correct as the value in [Pages] is generated after complete rendering of the report. Thus, this addition to a specific value will not work here for the page total.
    An alternative is to re-render the report so that we have a PageTotal in hand first. This can then be used to add to a default value and generate the expected results.
    The modified application showing the same is attached for your reference.
    prj_FlexReport -Re_render.zip
  • Posted 19 June 2019, 3:48 am EST
    HI esha.dhir, thansk for answer. but i have a wrong when run my example with your suggestions.
    private pageTotal = 0;
    c1FlexReport1_EndReport()
    pageTotal = c1FlexReport1.PageCount;
    c1FlexReport1_StartSection()
    if (e.Section == SectionTypeEnum.PageFooter)
    int pageDefaut = 5; // parameter from report 1
    int total = pageTotal + pageDefaut;
    tf.Text = "Page " + (e.Page +pageDefaut) + “/” + total;
    => Total of report 2 is not true. because Total variable only exit when report EndReport() function runed,
    => in StartSection() Total is only pages of report 1 anytime
    EX: report 1 return 5 pages
    report 2 is show: page 6/5 …->… page. 10/5
    where is wrong ?
  • Posted 19 June 2019, 5:57 am EST
    Have you used report 2 as the same report instance?
    Note that I have called Render method twice in the button’s event handler:
     private void paraButton_Click(object sender, EventArgs e)
    [b]  c1FlexReport1.Render();
    [/b]            //Render again. This time, the PageCount from the previous rendering is used to get the total page count and then add the default variable value to it.
    [b]           c1FlexReport1.Render();[/b]
     c1FlexViewer1.DocumentSource = c1FlexReport1;
    Did you do it in the same manner in your application?
  • Posted 20 June 2019, 9:12 pm EST
    Hi esha.dhir.
    thanks for support me, exactly that’s right.
    my project run well.
