Pre-requisite license of True DBGrid DLL compilation stops VSTS auto build
Posted by: aniruddha.guha on 17 October 2017, 6:39 am EST
    Posted 17 October 2017, 6:39 am EST
    We are using True DBGrid in our .NET project. This requires a first time registration while we perform build of the project. When we build from Visual Studio (v2015) it asks through a popup for the license key first time then performs the build. Next onwards it somehow understand this registration and perform build without asking again. This procedure works fine in on-prem Visual Studio. But currently we are trying to move our solution to VSTS cloud. And this pre-requisite license of True DBGrid stops our build pipeline, since neither we can procedure the popup during auto-build nor we can let VSTS cloud server know about that license key. Can you advice how we can successfully let VSTS server know about the license of this 3rd party True DBGrid component? I believe when we run it from on-prem Visual Studio the license successfully register the True DBGrid component into our local server. But this simply we can not do in VSTS cloud server. Can you please help us to solve this problem and adopt VSTS DevOps feature successfully? Thanks
  • Posted 18 October 2017, 5:55 am EST
    Could you please make sure that the machine you are the building the project is licensed properly. Also, could you please make sure that the licenses.licx file contain the entry for the
    C1TrueDbGrid control.
    Please do let us know if the above two requirements are already met and still the project shows nag screen.
    Ruchir Agarwal
