SetRedraw function error in VSFlexGrid 8.0
Posted by: sw0929.kim on 11 September 2020, 9:40 pm EST
  • Posted 11 September 2020, 9:40 pm EST
    I am currently using VSFlexGrid 8.0.
    I have contacted you once before, but it has not been resolved yet, so I will contact you again. At that time, I did not know exactly when the problem occurred, but now I have found the time when it occurred.
    When I use the SetRedraw function, the Grid disappears intermittently and the program ends. When I check the log the moment it occurs, the return value of the GetRows function is changed to 0.
    Currently, the 8.0.20052.221 version of the OCX is being used, but the phenomenon is the same even if the latest version, 8.0.20182.321 version is used.
    If I delete 1 grid line and add 1 grid line every 100ms, a problem occurs within a few hours.
    (RemoveItem, AddItem functions)
    I’m using Visual Studio 2010, 2012, and I’m not sure, but the above seems to only happen with Windows 7 operating system. There was no problem when using Windows XP, and Windows 10 is also confirmed to have no problem.
    I hope there is a way to solve the problem.
  • Posted 15 September 2020, 7:20 am EST
    It seems to be a specific issue with the application or the environment. Can you please share a small sample demonstrating the problem at your end? This would help me in escalating the issue to the developers, if needed.
