SpreadCom Dll control is not working with Char 8.0 ActiveX (ocx) control
Posted by: eng.choong on 5 March 2019, 11:02 am EST
    Posted 5 March 2019, 11:02 am EST
    Hi All,
    I’m working on a MFC application and in which I’m using both spreadcom dll control (via a custom control) and Chart ActiveX control on same dialogbox. But its not working my application getting crashed, But if I use single control on the same dialog box it working fine, I’m not understanding what is the issue here. For spreadcom control I’m using dll and the class is fpSpread80 and below are the dll my application consuming for the same. For Chart control I register the OCX file and using the GUID in my source file to get the reference of the control.But while My application run it is conflicting the resource id of both the control at run time crashed.
    1. SPR32D80.DLL
    2. SPR32D80.lib
    3. fpSPR80.OCX
    4. FPSPRU80.ocx
  • Posted 7 March 2019, 2:33 am EST
    You can use the OCX for Spread in your project.
    Please refer to the installed demo sample on your machine which shows how you can use spread in MFC dialog based application:
    C:\Program Files (x86)\FarPoint Technologies\Spread 8\Samples\ActiveX\Vc\CTSample
    May I know what error message are you getting when using Spread in MFC application?
    Deepak Sharma
