Support font.ttf file
Posted by: mayur.purandare on 16 January 2019, 1:25 am EST
    Posted 16 January 2019, 1:25 am EST
    Dear
    I am using this library C1.C1Pdf for generating PDF files.
    I am able to generate PDF file successfully. But I want to apply MS Gothic font on generated pdf file.
    How should I apply MS Gothic font while creating PDF?
  • Posted 17 January 2019, 4:19 am EST
    You can embed a font in the application and use it for the Font while drawing a string, after you have set the FontType property of C1PdfDocument to Embedded.
    C1PdfDocument1.FontType = C1.C1Pdf.FontTypeEnum.Embedded
    ’ Add content to the page.
    Dim rect As RectangleF = C1PdfDocument1.PageRectangle
    rect.Inflate(-72, -72)
    Dim pfCol As New System.Drawing.Text.PrivateFontCollection
    pfCol.AddFontFile(“…/…/MS Gothic.ttf”)
    Dim font As Font = New Font(pfCol.Families(0), 12)
    C1PdfDocument1.DrawString(TextBox1.Text, font, Brushes.Black, rect)
    This has been shown in the attached sample.
    Esha[zip filename="prj_PDFDocument_EmbeddedFont.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-8a239378-6247-47f1-a76e-56fa86e2644b.zip[/zip]
  • Posted 2 April 2019, 1:59 am EST
    Thanks for the reply.
    I got the font from my client. It is a .FON font. It works good on the screen.
    Is there any ways to apply apply .fon font while creating PDF.
  • Posted 3 April 2019, 12:43 am EST
    .FON files cannot be used while creating PDF , in C1Pdf.
    As per the description in the below mentioned documentation link for FontTypeEnum, ttf files can only be embedded for fonts, in pdf created using C1Pdf:
    https://help.grapecity.com/componentone/NetHelp/c1pdf/webframe.html#C1.C1Pdf.4~C1.C1Pdf.FontTypeEnum.html
    Regards.
