Upgrading Winform From 20.20121.33274 (2012) to 20.20213.532 (2021)
Posted by: jhalbert on 4 August 2023, 8:06 am EST
  • Posted 4 August 2023, 8:06 am EST
    our product is using the following controls with version 20.20121.33274 (2012)
    we are planning to upgrade them to 20.20213.532 (2021) which is a major gap.
    Just wanted to know what sort of regression issues we should expect.
    like can it cause layout issues, functional problems etc.
    C1.C1Pdf.2.dll
    C1.Win.C1Chart.2.dll
    C1.Win.C1Command.2.dll
    C1.Win.C1GanttView.2.dll
    C1.Win.C1Input.2.dll
    C1.Win.C1List.2.dll
    C1.Win.C1Ribbon.2.dll
    C1.Win.C1SuperTooltip.2.dll
    any suggestion is highly appreciated.
  • Posted 7 August 2023, 3:33 am EST
    Hello Jeremy,
    It is good to hear that you are planning to upgrade from an old version because that version is quite old and out of support.
    As you are planning to upgrade, we would suggest you upgrade to the latest version 2023v2.
    You can go through the following blog to check how to migrate from an old version:
    https://www.grapecity.com/blogs/how-to-migrate-to-net-framework-4-8-using-componentone
    As per your mentioned references, it seems that you are using the old Ribbon controls which is in maintenance mode so you can check our latest simplified Ribbon controls and update it too:
    https://www.grapecity.com/blogs/migration-classic-ribbon-to-new-ribbon
    If you face any issues while migration then please let us know.
    Note: We have replied the same on your support thread so please continue the thread in a single place to avoid confusion.
