Posted 10 September 2017, 12:33 pm EST
I have been sitting here for 15 minutes and nothing is happening.
If this is any indication of the quality of this software … I am not impressed.
This is awful.
Forums Home / ComponentOne / General Discussion
Posted by: ecotter on 10 September 2017, 12:33 pm EST
This is awful.
Hello Ecotter,
Please check whether you have space available in your machine for the installation. I tried installing the 2011v3 setup in Windows 7 32-bit machine and it worked correctly. You can download the same from the following url :
http://www.componentone.com/IntelliSpell/Download/
If the problem persists, could you please let me know which version of C1Intellispell are you installing and what is the configuration of the machine?
Richa
Richa,
Thank you for the helpfull information.
It did finally start to install over 10 mins later. I have windows 7 64bit with aprox 2 gb of space remaining. I am not sure why this particular piece of software took so long to install.
I have not had this problem before. Perhaps a VPN session or something was holding onto and instance of VS20101 and that was holding up the install.
Once I had it up it seems to work excellent. Thank you.
Eric
Posted 2 November 2021, 7:51 am EST
Well for me, it was easy and fast to install it…
Maybe some of your System issue…
Few reason which may help you to increase your installation speed :-
Check your system where it is lagging.
Jim
