Zip directory
Posted by: kisar on 8 June 2018, 3:23 am EST
    Posted 8 June 2018, 3:23 am EST
    Hi, I’m using the c1.C1Zip library
    I want to zip a folder, but I need that the folder too is in the zip file.
    When I use “addfolder” it add the content inside the directory,
    but I loose the main directory.
    Can you say how can I do.
    Example : if I zip this directory1 I what to find it in the zip and not only file1 and file2.
    directory1	\file1
    			\file2
    thank you
  • Posted 11 June 2018, 7:22 am EST
    Hi!
    It seems that you are trying to add a zipped folder to another zipped folder. For this, use Entries.Add (http://help.grapecity.com/componentone/NetHelp/c1zip/webframe.html#C1.C1Zip.4~C1.C1Zip.C1ZipEntryCollection~Add.html) method instead of AddFolder method.
    For demonstration purpose, you can find C1Zipper sample (refer AddFileList function in Form1.cs file) at this location :
    \Documents\ComponentOne Samples\WinForms\C1Zip\CS\C1Zipper
    The code should look something like this :
    // add files
    foreach (string file in files)
             // add the file
             try
                      _zipFile.Entries.Add(file, pathLevels);
                      Application.DoEvents();
             catch (Exception x)
                     //Exception handling code here...
    Best regards,
    Meenakshi
  • Posted 13 June 2018, 1:10 pm EST
    Hi, no maybe i did not explain good,
    If we refer to the directory above
    and i user zip.AddDirectory(path_mydirectory1)
    in the zip file i will find : file1 and file2.
    I would like to have the main directory1 as first entry.
    Thanx
  • Posted 15 June 2018, 12:40 am EST
    Hi!
    So you are willing to add this zipped folder (containing file1 and file2) into directory1. In this case, I would like to inform you that you can perform operations such as add, delete within a main parent zipped folder only.
    There is no workaround to add zipped file(s) and folder(s) into a simple folder using C1ZipFile.
    Do let me know if there is anything with which I can help you.
    Best regards,
    Meenakshi
