Dirty Cells
Posted by: nchalla on 11 November 2017, 4:27 pm EST
    Posted 11 November 2017, 4:27 pm EST
    Is there any way I get all dirty cells after updating a formula/value for a cell?
  • Posted 13 November 2017, 10:16 am EST
    I have asked the development if there is a direct way of finding all dirty cells updated through formula or using Value.
    I will let you know as soon as I get an update on this. The tracking id for this issue 249737.
    Deepak Sharma
  • Posted 15 November 2017, 2:28 pm EST
    Any update on this?
  • Posted 16 November 2017, 5:18 am EST
    I have asked for an update from the development team about this issue. I will let you know as soon as I get an update on this.
    Deepak Sharma
  • Posted 18 December 2017, 5:41 am EST
    Developer has provide the following solution to get the dirty range:
    class Program
            static void Main(string[] args)
                Workbook book = new Workbook();
                IWorksheet sheet1 = book.Worksheets[0];
                sheet1.Range["a1"].Value = 5;
                sheet1.Range["a2"].Value = 10;
                sheet1.Range["c1"].Formula = "2*a1*a2";
                sheet1.Range["e1"].Formula = "3*a1*a2";
                IWorksheet sheet2 = book.Worksheets.Add();
                sheet2.Range["a1"].Formula = "4 * sheet1!a1 * sheet1!a2";
                sheet2.Changed += Sheet2_Changed;
                sheet1.Changed += Sheet1_Changed;
                sheet1.Range["a2"].Value = "20";
                Console.ReadLine();
            private static void Sheet2_Changed(object sender, RangeEventArgs e)
                Console.WriteLine("Sheet2 Affected Ranges: " + e.Range);
            private static void Sheet1_Changed(object sender, RangeEventArgs e)
                Console.WriteLine("Sheet1 Affected Ranges: " + e.Range);
    Deepak Sharma
