Posted 18 October 2020, 2:21 pm EST
I’m trying to extract the data in a Excel file in a format that I can easily query.
Is there a simple way to do this?
I’m thinking something along the line of a .net DataTable…
Forums Home / Document Solutions / Document Solutions for Excel, .NET Edition
Posted by: mth on 18 October 2020, 2:21 pm EST
Posted 19 October 2020, 8:16 am EST
Hello Mathieu,
You can apply the format to the Range of cell as demonstrated in the demo samples given below:
https://www.grapecity.com/documents-api-excel/demos/numberformat
Can you please specify the format in which you want to export the data?
Posted 19 October 2020, 11:59 am EST
I’m not looking to format data.
I’m looking to extract the content of an excel file and import it in a .net DataTable for example.
Posted 20 October 2020, 8:16 am EST
Hello Mathieu,
There is no direct way to achieve this but as a workaround, you can iterate through each cell and store it in DataTable. Please find the attached sample implementing the same.
GcExcelDemo.zip
Posted 5 November 2020, 5:20 pm EST
Hi Prabhat,
Is there a way to get the numbers of rows from the worksheet?
I’ve tried using:
var count = worksheet.Rows.Count;
But I’m getting 1048576 rows for a file with only 7 rows who have some values.
Posted 6 November 2020, 1:06 am EST
Hello Mathieu,
You can use the code snippet to get the number of rows that have been used in the excel file:
var count = worksheet.UsedRange.RowCount;
Prabhat Sharma,
