Freezing position changed after saving
Posted by: yyoshimura on 15 December 2020, 2:07 am EST
    Posted 15 December 2020, 2:07 am EST
    Dear support,
    We’ve just encountered a problem about freezing panes. The freezing row and column changed after saving using the api.
    Please refer the attachment for reproduction.
    The input file [I002_Test.xlsx] is freezed at cell T27. When saved with the api the freezing position of output file [I002_Test_saved.xlsx] has changed to cell G21.
    It seems that it occurs when first row and column are scrolled to invisible state and then set the freezing row and column.
    Please help to investigate this issue. We are expecting the output to be the same after saving.
    gcexcelperformance.zip
  • Posted 16 December 2020, 3:43 am EST
    We have forwarded this to the developers and will let you know once we get the update from their end.[Intenal Tracking ID: DOCXLS-3488]
  • Posted 11 January 2021, 3:58 am EST
    The issue has been fixed in the latest version 4.0.2 of GcExcel, please update your builds to avoid this issue.
    https://www.nuget.org/packages/GrapeCity.Documents.Excel/
  • Posted 11 January 2021, 7:45 pm EST
    Thank you! We’ll try it and update the result here.
  • Posted 12 January 2021, 8:20 pm EST
    We confirmed that the problem is solved with the latest version v4.0.2. Thank you very much for your support.
