Getting the cell value a named cell refers to
Posted by: lpagliaro on 9 November 2017, 11:02 am EST
    Posted 9 November 2017, 11:02 am EST
    Hello. I’m trying to get the cell value a named cell refers to but I’m not being able to figure out how to do it.
    For example, if I create a named cell:
    workbook.Names.Add(“test”, “=$1$A”);
    and then I do this to try to get the value this named cell I created refers to:
    var names = workbook.Names;
    var name = names[“test”];
    cellValue = name.RefersTo;
    cellValues contains the following string: “='Bravo Co '!$A$1”
    How do I do to get the value of the cell referenced to using the string from cellValues?
    Regards.
  • Posted 9 November 2017, 11:10 am EST
    Bravo Co is the name of the sheet.
    By value I mean the calculated value, so if the named cell refers to a cell that has a formula I want the calculated value.
  • Posted 10 November 2017, 11:37 am EST
    You can get the Cell index by using RefersTo property of of Name. Then you can use the cell index to get the cell value using the code as follows:
    string cellname = name.RefersTo;
    // you would need to modify/truncate the string to get correct cell index e.g 'A1'.
    string cellvalue= worksheet.Range[cellname].Value.ToString();
    I hope it helps.
    Deepak Sharma
  • Posted 10 November 2017, 11:57 am EST
    Thanks for the help! It worked.
