Google Sheets Query
Posted by: srinivas.suravarapu on 27 August 2025, 9:29 am EST
    Posted 27 August 2025, 9:29 am EST
    Hi
    Is there anyway we can convert a Google sheets workbook into a DSExcel workbook object, is there any potential we could do it using your API? or even alternative advice would be appreciated
    Thank you
    Sri
  • Posted 27 August 2025, 11:05 pm EST
    Based on our understanding, you’re looking to load a Google Sheets workbook (stored in the cloud) directly into a DsExcel Workbook object. While DSExcel doesn’t support directly loading native Google Sheets formats (which are proprietary and cloud-based), it is possible to achieve this programmatically by exporting the sheet to .xlsx format via a URL and loading the resulting stream into DSExcel.
    Please refer to the code snippet below that demonstrates the same:
    string exportUrl = "Google-shareable-xlsx-format-url";
    HttpClient client = new();
    HttpResponseMessage response = await client.GetAsync(exportUrl);
    response.EnsureSuccessStatusCode();
    Stream remoteStream = await response.Content.ReadAsStreamAsync();
    Workbook workbook = new();
    workbook.Open(remoteStream);
    You can further refer to the attached code sample that uses the above code snippet and loads the Google sheet into DsExcel (see below).
    Please let us know if you have any other understanding or require additional assistance.
    Chirag Gupta
    Attachment: SheetLoad.zip
