How to use Excel formula for template field
Posted by: supply on 24 May 2023, 8:18 am EST
    Posted 24 May 2023, 8:18 am EST
    Hi, please help with my request.
    I use a template to get Excel document. One field in datasource represents a date in ISO format. I’d like to insert as the date, e.g. I’m going to use Excel formula (DATEVALUE). But I cannot find a way to specify the formula in my template.
    I’ve tried the following expressions
    • {{==DATEVALUE({{field}}) }}
    • =DATEVALUE({{field}})
    Is there a proper way to get what I want?
    P.S. We have bought the license.
  • Posted 25 May 2023, 7:41 am EST
    Apologies for the inconvenience caused.
    There is no direct way to apply the formula with the field name in the template but you can use the cell address in with the formula in the template cell. Please see the attached template and sample implementing the same.
    You can hide the column with the actual data if you do not want to show it.
    If you have some other requirement then please explain us in brief.
    DataTable_csharp_Modified.zip
