Posted 3 April 2018, 1:23 pm EST
The subtotal function with sum (i.e. 9) is not generating correct number when imported from JSON.
File test.json (attached) is generated from “SpreadSheet Designer” which calculates the formulas and value correctly.
We take that same JSON file to following Spread.Workbook to generate Excel and PDF as below :
var workbooks = new GrapeCity.Documents.Spread.Workbook();
workbooks.Open(mem); // where mem is stread from test.json file
string spreadJson = workbooks.ToJson();
Generated spreadJson is below :
"dataTable": {
"0": {
"0": {
"value": 123
"1": {
"0": {
"value": 234
"2": {
"0": {
"formula": "SUBTOTAL(9,A1:A2)",
"value": 357
"3": {
"0": {
"formula": "SUBTOTAL(9,A1:A3)",
[b] "value": 714,[/b]
"style": "__builtIn-1---Sheet1"
As you see in above Generated JSON, the value for row “2” and “3” should be SAME since SUBTOTAL() function needs to skip the other subtotals in the range. The last SUBTOTAL (we use as Grand Total) is doubling the values up … it suppose to be (357) and not adding other subtotals.
Please Advice as our generated PDF is not working correctly for Tax purpose.
Appreciated!
Jayesh
