NullReferenceException occurred when opening some Excel files
Posted by: yyoshimura on 19 January 2022, 12:54 am EST
    Posted 19 January 2022, 12:54 am EST
    We noticed that when opening some workbooks using the library it will always fail with NullReferenceException. The stack trace is as following. Please refer attachment for reproduction. We are using version V5.0.1 of the library.
    Please help to investigate this issue. Thank you.
       at GrapeCity.Documents.Excel.Drawing.ᝌ.ᜀ(᠓ A_0, ៥ A_1)
       at GrapeCity.Documents.Excel.Drawing.ᝌ.ᜀ(᠔ A_0, ៥ A_1)
       at GrapeCity.Documents.Excel.Drawing.ᝌ.ᜀ(ᠢ A_0, ៥ A_1)
       at GrapeCity.Documents.Excel.Drawing.ᝌ.FromOOModel(ឿ t, ៥ cultureProvider)
       at GrapeCity.Documents.Excel.Drawing.ᝎ.ᜀ(ឧ A_0, Boolean A_1, ៥ A_2)
       at GrapeCity.Documents.Excel.Drawing.ᝎ.ᜀ(ឧ A_0, ៥ A_1)
       at GrapeCity.Documents.Excel.Drawing.ᝋ.FromOOModel(ឧ t, ៥ cultureProvider)
       at GrapeCity.Documents.Excel.Drawing.ᜣ.ᜁ(ឮ A_0, ៥ A_1, Boolean A_2)
       at GrapeCity.Documents.Excel.Drawing.ᜣ.FromOOModel(ឹ ooModel, ៥ cultureProvider)
       at GrapeCity.Documents.Excel.Drawing.᝼.ᜁ(᢭ A_0, ៥ A_1, Boolean A_2)
       at GrapeCity.Documents.Excel.Drawing.᝼.FromOOModel(ᢷ anchor, ៥ cultureProvider)
       at GrapeCity.Documents.Excel.Drawing.᜹.ᜀ(ᜊ A_0, ᢷ A_1, ᜣ A_2)
       at GrapeCity.Documents.Excel.Drawing.ព.ᜁ(៥ A_0)
       at GrapeCity.Documents.Excel.ᮯ.᳜()
       at GrapeCity.Documents.Excel.Workbook.AfterOpen()
       at GrapeCity.Documents.Excel.Workbook.OpenInternal(Stream fileStream, String password, OpenOptions openOptions, Boolean isMacroEnabled, Boolean digitalSignatureOnly)
       at GrapeCity.Documents.Excel.Workbook.Open(Stream fileStream, OpenFileFormat fileFormat)
       at GrapeCity.Documents.Excel.Workbook.Open(String fileName, OpenFileFormat fileFormat)
       at GrapeCity.Documents.Excel.Workbook.Open(String fileName)
    gcexcelperformance.zip
  • Posted 20 January 2022, 7:38 am EST
    Thank you for reporting this issue.
    We too can observe the issue and escalated this to the development team for investigation. We will let you know as soon as we get any update on this from their end.
    [Internal Tracking ID: DOCXLS-5418]
  • Posted 6 March 2022, 3:10 pm EST
    Your issue has been in the 5.0.4 release of GcExcel. Please update to the latest version to fix this issue.
    https://www.nuget.org/packages/GrapeCity.Documents.Excel/5.0.4
  • Posted 6 March 2022, 8:57 pm EST
    Thank you for your support. We confirmed that the issue is fixed in 5.0.4.
