Posted 23 July 2020, 11:53 am EST
In Version 3.2.0.0 the Workbook Open method fails to open a document from a memory stream stating that the ‘File contains corrupted data.’. In Version 3.0.4.0 the Workbook Open method opens from a memory stream without issue.
Is opening from a memory stream in 3.2.0.0 no longer supported or might this be an issue from an underlying component?
Here is the stack trace from the issue:
at MS.Internal.IO.Zip.ZipIOEndOfCentralDirectoryBlock.FindPosition(Stream archiveStream)
at MS.Internal.IO.Zip.ZipIOEndOfCentralDirectoryBlock.SeekableLoad(ZipIOBlockManager blockManager)
at MS.Internal.IO.Zip.ZipArchive…ctor(Stream archiveStream, FileMode mode, FileAccess access, Boolean streaming, Boolean ownStream)
at MS.Internal.IO.Zip.ZipArchive.OpenOnStream(Stream stream, FileMode mode, FileAccess access, Boolean streaming)
at System.IO.Packaging.ZipPackage…ctor(Stream s, FileMode mode, FileAccess access, Boolean streaming)
at System.IO.Packaging.Package.Open(Stream stream, FileMode packageMode, FileAccess packageAccess, Boolean streaming)
at ᯬ.ᜀ(Stream A_0)
at ᣖ.ᜀ(ᢜ A_0, Stream A_1, ᬼ A_2)
at ᢢ.ᜀ(ᬼ A_0, Stream A_1, ᬪ A_2, Boolean A_3)
at GrapeCity.Documents.Excel.Workbook.OpenInternal(Stream fileStream, String password, OpenOptions openOptions, Boolean isMacroEnabled, Boolean digitalSignatureOnly)
at GrapeCity.Documents.Excel.Workbook.Open(Stream fileStream, OpenOptionsBase options)
at GrapeCityTableBindingDemo.BindTableExcel.BindThatTable() in C:\Users\ryanw\source\repos\GrapeCityTableBindingDemo\GrapeCityTableBindingDemo\BindTableExcel.vb:line 47
at GrapeCityTableBindingDemo.Module1.Main() in C:\Users\ryanw\source\repos\GrapeCityTableBindingDemo\GrapeCityTableBindingDemo\Module1.vb:line 4
Thank you for any help you can provide.
