Row "Hidden" property giving wrong value
Posted by: nchalla on 12 November 2017, 4:20 pm EST
  • Posted 12 November 2017, 4:20 pm EST
    The Row “Hidden” property is always false even though the row is hidden in Excel file. But the Row height was coming as zero (0).
    Example Code:
    workbook.Open("Workbook.xlsx");
                IWorksheet worksheet = workbook.Worksheets[0];
                worksheet.Protection = false;
                worksheet.Range["A1:A3"].Value = 121;
                string str = string.Empty;
                var range = worksheet.GetUsedRange();
                for(var i = 0; i < range.Rows.Count; ++i) {
                    str += i + "-" + range.Rows[i].Hidden + "\n";
  • Posted 13 November 2017, 10:08 am EST
    This is the designed behavior of Spread.Services. After importing the Excel file the hidden rows height is set to 0 knowingly. You would need to set the height to a number other than 0 to make it visible.
    Deepak Sharma
  • Posted 13 November 2017, 1:00 pm EST
    Thanks. What is the use of “Hidden” property then? According to your documentation, it says “Gets or sets the property which specifies whether rows or columns should be hidden.”
  • Posted 14 November 2017, 8:59 am EST
    I will discuss this issue with the development team and let you know the possible reason for keeping this behavior.
    I will let you know as soon as I get any update on this.
    Deepak Sharma
  • Posted 14 November 2017, 9:08 am EST
    The tracking id for this issue is #249834
    Deepak Sharma
  • Posted 1 September 2018, 3:23 pm EST
