SpecialCells with SpecialCellType.Formulas of single cell is not correct
Posted by: yyoshimura on 8 December 2022, 1:33 am EST
    Posted 8 December 2022, 1:33 am EST
    We are using IRange.SpecialCells(SpecialCellType.Formulas) to get the cells with formulas in the range. With multiple cells range it is working as expected but with single cell the result is not as we expected. Please refer attachment for reproduction.
    Please help to investigate this issue. Thank you.
    gcexcelperformance.zip
  • Posted 12 December 2022, 12:23 am EST
    Thank you for reporting this issue. We too can observe the issue and escalate this to the development team for investigation. We will let you know as soon as we get any update on this from their end.
    [Internal Tracking ID: DOCXLS-7228]
  • Posted 14 December 2022, 6:24 am EST - Updated 14 December 2022, 6:29 am EST
    Hello Yukinori,
    As per the developers, This behavior is intended. Because Microsoft Excel looks in all cells in the worksheet of the specified Range if the Range is a cell.
    Sub Macro1()
    Cells.ClearContents
    Range(“A1”).FormulaR1C1 = “=1+2”
    Range(“A2”).FormulaR1C1 = “=2+3”
    Set a3FindFormulas = Range(“A3”).SpecialCells(xlCellTypeFormulas)
    MsgBox a3FindFormulas.Address
    End Sub
    f you want to check whether a range has formula cells, you need to use Range.Count and Range.HasFormula first.
    If Range.Count =1 then use Range.HasFormula . Otherwise, use Range.SpecialCells.
    private static IRange FindFormulaCellsExact(IRange lookIn)
    if (lookIn == null)
    return lookIn;
    if (lookIn.Count < 2)
    return lookIn.HasFormula ? lookIn : null;
    return lookIn.SpecialCells(SpecialCellType.Formulas);
  • Posted 14 December 2022, 8:56 pm EST
    Thank you for your detailed explanation and it really helps. We can try the provided method to get the exact result.
