Posted 18 November 2022, 9:22 am EST
I’m interested in setting up a system where I can take a portion of a data set, use the spread js front end to apply transformations (pivot, calculations, etc) and get transformation json. Then, apply this transformation to the original data set (could be millions of rows) on the backend to create a new data set. This would also allow my system to apply this transformations to new versions of this data set in the future. Is it possible to use Spread in this way, to fed it a data set and transformation and get a new data set spit out on the other side without a UI in the middle?
