worksheet.Columns.AutoFit() not taking into account filter dropdowns
Posted by: mth on 22 July 2020, 6:33 pm EST
    Posted 22 July 2020, 6:33 pm EST - Updated 29 September 2022, 3:38 pm EST
    I noticed that this code:
    worksheet.Columns.AutoFit();
    Will not take into account the presence of the dropdown to fit the content so the end result is that the column header is not showing all the text. Is there a workaround to resolve this?
    Using Excel autofit will correctly take into account the presence of the dropdown. See screenshots.
  • Posted 23 July 2020, 5:48 am EST
    Hello Mathieu,
    AutoFit is working perfectly at my end. When using the table in the excel, the last character is overlapped by the dropdown sign.
    You can use the code snippet given below as a workaround to make it look properly:
     Workbook wb = new Workbook();
     IWorksheet sheet = wb.Worksheets[0];
     sheet.Rows[0].Value = new object[] { "TotalColumnHeader", "TotalColumnHeader" };
     ITable table = sheet.Tables.Add(sheet.Range["A1:B2"], true);
     sheet.Range["A1:B2"].Columns.AutoFit();
     for(int i=0;i<table.Columns.Count;i++)
     sheet.Columns[i].ColumnWidth = sheet.Columns[1].ColumnWidth + 2;
     wb.Save("demo.xlsx");
    ``` If you need any other help, please let me know.
  • Posted 23 July 2020, 10:13 am EST
    Thank you Sir. That worked perfectly.
    Great day to you.
