Posted 6 January 2021, 10:55 am EST - Updated 30 September 2022, 8:12 am EST
I’m using TextLayout and it’s method AppendAnchoredObject with the Option wrapText true, so that the Text goes around each Object. The issue I face is that when having several Anchored Objects then it can happen that they will overlap, so that one Object will hide another one.
Is it possible to solve this with an Option or do I have to do that manually?
A manual workaround I could image is
Append the Text & AnchoredObjects to the TextLayout.
RecalculateGlyphs.
PerformLayout(false).
Get the Position of each AnchoredObject and store in a List MyObjects.
Verify that the Objects within MyObjects does not overlap each other. If they do, then manually define a new position of the Objects.
Remove all AnchoredObjects from TextLayout.
Add all MyObjects to TextLayout.ObjectRects.
DrawTextLayout.
Another idea to explicitly reposition the Anchored Objects is to tweak individually the MinLeft/Top, MaxRight/Bottom Properties. But I still have to manually calculate the position of each Object.
See the attached Code for an example of overlapping Anchored Objects.
public static class SupportReport
public const float Resolution = 72f;
public const float Point = 1f;
public const float Inch = Point * Resolution;
public const float CM = Inch / 2.54f;
public const float MM = CM / 10;
public static void OverlappingAnchoredObjects(Object docObject)
var doc = (GrapeCity.Documents.Pdf.GcPdfDocument)docObject;
var page = doc.NewPage();
page.PaperKind = GrapeCity.Documents.Common.PaperKind.A4;
page.Landscape = false;
var pageSize = page.GetRenderSize(Resolution, Resolution);
var graphics = page.Graphics;
graphics.Resolution = Resolution;
var rect = new System.Drawing.RectangleF(2.5f * CM, 2.5f * CM, pageSize.Width - 5 * CM, pageSize.Height - 5 * CM);
graphics.DrawRectangle(rect, new GrapeCity.Documents.Drawing.Pen(System.Drawing.Color.Pink, 0.1f * MM));
var text = new GrapeCity.Documents.Text.TextLayout(graphics.Resolution)
MarginLeft = rect.X,
MarginTop = rect.Y,
MarginRight = 0,
MarginBottom = 0,
MaxWidth = rect.Right,
MaxHeight = rect.Bottom,
AlignmentDelayToSplit = true,
EllipsisCharCode = '.',
ParagraphAlignment = GrapeCity.Documents.Text.ParagraphAlignment.Near,
TextAlignment = GrapeCity.Documents.Text.TextAlignment.Leading,
LastLineIsEndOfParagraph = true,
var textFormat1 = new GrapeCity.Documents.Text.TextFormat()
Font = GrapeCity.Documents.Text.FontCollection.SystemFonts.FindFamilyName("Arial", true, false),
FontSize = 6,
ForeColor = System.Drawing.Color.Red,
UseTypoMetrics = true, // cross platform independent
EnableFontHinting = true, // is default true
FontSizeInGraphicUnits = false, // typographic units
string lorem = "Lorem ipsum dolor sit amet, consectetur adipiscing elit. Integer sodales iaculis dictum. Nam in porta dolor. Pellentesque neque orci, maximus in accumsan eget, tincidunt nec eros. Aenean vitae nisi vel purus maximus dignissim. Proin sagittis elementum pharetra. Mauris eu tellus pretium, luctus dui eget, pharetra velit. Nunc fermentum tortor ante, eget sodales sapien imperdiet ut.";
lorem += " ";
text.Append(lorem + lorem + lorem, textFormat1);
foreach (var size in new int[] { 1, 2, 3, 4, 5, 6 })
text.Append(lorem, textFormat1);
text.Append(" Anchor:", textFormat1);
var anchor1 = text.AppendAnchoredObject(size * CM, size * CM, true);
anchor1.AttachToPreviousChar = true;
anchor1.MinLeft = 0;
anchor1.MaxRight = pageSize.Width;
anchor1.KeepInHorizontalBounds = true;
anchor1.MinTop = 0;
anchor1.MaxBottom = pageSize.Height;
anchor1.KeepInVerticalBounds = true;
anchor1.HorizontalOffset = 0 * CM;
anchor1.VerticalOffset = 0;
anchor1.HorizontalPosition = GrapeCity.Documents.Text.HorizontalPosition.CharRightOut;
anchor1.VerticalPosition = GrapeCity.Documents.Text.VerticalPosition.CharBottomIn;
text.RecalculateGlyphs();
text.PerformLayout(false);
graphics.DrawTextLayout(text, System.Drawing.PointF.Empty);
// Draw all Anchored Objects
var rnd = new Random();
foreach (var a in text.AnchoredObjects) {
var randomColor = System.Drawing.Color.FromArgb(rnd.Next(256), rnd.Next(256), rnd.Next(256));
graphics.DrawRectangle(a.ContentObjectRect.ToRectangleF(), new GrapeCity.Documents.Drawing.Pen(randomColor, 0.3f * MM));
#endregion
Thank You
