Posted 21 May 2019, 2:34 am EST
Are the components able to create PDF/A documents (A-1, 2 or 3)?
Manuel
Forums Home / Document Solutions / Document Solutions for PDF
Posted by: manuel.stix on 21 May 2019, 2:34 am EST
Manuel
Posted 22 May 2019, 1:07 am EST
Hi Manuel,
Yes, GcPdf supports the creation of PDF/A documents and allows to set the PDF/A conformance levels as well.
It has been mentioned at the below mentioned documentation link, for your reference:
http://help.grapecity.com/gcdocs/gcpdf/onlinehelp/webframe.html#KeyFeatures.html
Also, refer the product sample at the following link, which shows how to create a PDF/A-3u conformant document:
http://demos.componentone.com/gcdocs/gcpdf/Samples/List#PdfA/codeCS
Note the usage of ConformanceLevel property of GcPdf here.
Posted 28 May 2019, 2:02 am EST
Hi Esha,
Thanks for answering! Since I am using C1PDF I would have to switch to a different licensed component - am I right?
Manuel
Edit: Seems to be available in C1 because I found a C1.C1Pdf.PdfAConformanceLevel Enum but not a corresponding Property on the C1PdfDocument Object…
Posted 28 May 2019, 3:33 am EST
Hi Manuel,
As the issue is posted under Grapecity Documents for PDF, I assumed your requirement to be related to the same product. Yes, Grapecity Documents for PDF is a separate product and thus, needs a different license. For C1Pdf related queries, you can post cases on the WinForms forum: https://www.grapecity.com/forums/winforms-edition
Yes, C1Pdf supports ConformanceLevel, as shown in the attached application. However, note that only PdfA2b is fully supported, as mentioned in the documentation: https://help.grapecity.com/componentone/NetHelp/c1pdf/webframe.html#C1.C1Pdf.4~C1.C1Pdf.PdfAConformanceLevel.html
