Posted 13 November 2018, 6:00 pm EST
I can’t find any information on how we might use this api to generate a PDF that can expire. Is it possible to do that?
Forums Home / Document Solutions / Document Solutions for PDF
Posted by: mkulik on 13 November 2018, 6:00 pm EST
Posted 14 November 2018, 6:17 am EST
PDF expiration is not supported with Documents for PDF.
Let us know if you need further assistance.
Posted 20 November 2018, 2:18 am EST
AFAIK, there is no standard mechanism built into PDF (defined in the spec) that provides real document expiration. But, there is a way to imitate expiration when the PDF is opened in a viewer that supports JavaScript (e.g. Adobe Acrobat), attached is a working example, here is the relevant code:
public class PdfExpire
// Expiry date (year, month index, day):
const string expDate = "2018, 10, 19";
readonly string jsclose =
"var rightNow = new Date();\r\n" +
$"var endDate = new Date({expDate});\r\n" +
"if(rightNow.valueOf() > endDate.valueOf()) {\r\n" +
// Remove next line to close the document right away without alert:
"app.alert(\"This Document has Expired.\");\r\n" +
"this.closeDoc();\r\n" +
"}\r\n" +
public void CreatePDF(Stream stream)
var doc = new GcPdfDocument();
var page = doc.NewPage();
var g = page.Graphics;
// Invisible button with action activated on page open:
var btnExpire = new PushButtonField();
btnExpire.Widget.Locked = true;
btnExpire.Widget.Rect = RectangleF.Empty;
// The JavaScript will compare the current date with the expiry date,
// and will close the document if the expiry date is in the past:
btnExpire.Widget.Events.AnnotationPageOpened = new ActionJavaScript(jsclose);
btnExpire.Widget.Page = page;
doc.AcroForm.Fields.Add(btnExpire);
Common.Util.AddNote(
$"If opened in a PDF viewer that supports JavaScript actions, this document will close if the current date is past {expDate} (2nd number is month's 0-based index).",
page);
// Done:
doc.Save(stream);
```[zip filename="PdfExpire.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-9717ff39-326a-494c-a3d4-ed617093d108.zip[/zip]
Hope this helps.
