Posted 16 February 2020, 5:43 am EST
I can not find how to set the horizontal alignment of text in cells in a table. For example, I would like all of the text in the 3rd table column to be centered.
Forums Home / Document Solutions / Document Solutions for Word
Posted by: david.sheppard on 16 February 2020, 5:43 am EST
Posted 17 February 2020, 5:27 am EST
Hi David,
There is no such class to set the properties at the column level and also there is no HorizontalAlignment property at cell level so you need to format the cells using Padding property to achieve the desired result.
https://www.grapecity.com/documents-api-word/docs/online/cell.html
https://www.grapecity.com/documents-api-word/docs/online/GrapeCity.Documents.Word~GrapeCity.Documents.Word.CellPadding~Left.html
Posted 17 February 2020, 9:10 am EST
Hello.
General-purpose solution is to define paragraph.Format.Alignment for every column cell’s paragraph.
Microsoft Word does the same thing when whole column is selected and alignment changed.
For few TableStyleOverride enum-defined columns it also can be solved using ConditionalStyle:
Style tablestyle = doc.Styles.Add("table style 1", StyleType.Table);
table.Style = tablestyle;
table.Format.StyleOptions = TableStyleOptions.LastColumn;
table.Style.Table.Conditionals[TableStyleOverride.LastColumn].ParagraphFormat.Alignment = ParagraphAlignment.Center;
A
