Insert Table at field
Posted by: david.sheppard on 10 February 2020, 6:09 am EST
    Posted 10 February 2020, 6:09 am EST
    I am trying to add a table at the location of a complexfield using the following code.
    tbl1 = ComplexField1.GetRange().Tables.Insert(location:=InsertLocation.After)
    The error that I get is:
    GrapeCity.Documents.Word.InvalidParentContentException: ‘Cannot insert content of type ‘Table’ into parent content of type ‘Paragraph’ because the content to insert can be a child only for the folowing content types: Body, Cell, ControlContent.’
  • Posted 11 February 2020, 7:53 am EST
    Hi David,
    Thank you for the code snippet. Using this code, I too got the exception and it looks like a limitation. So, I have forwarded it to the developer [Doc-1719].
    I will keep you updated with the progress on this.
    Ruchir
  • Posted 11 February 2020, 8:26 am EST
    Thank you for your response. My preference would be for the command to insert a table to work like the insert command for new text. This is the command to insert text:
    ComplexField1.GetRange().Runs.Insert(“AAA”, InsertLocation.Before)
    The command to insert a table should look like:
    Dim tbl1 as table
    tbl1 = ComplexField1.GetRange().Tables.Insert(Columns as integer, Rows as integer, InsertLocation as InsertLocation) as table
  • Posted 12 February 2020, 3:18 am EST
    Hi David,
    Thanks, I have shared the suggestion with the developers and as soon as I receive an update, I will let you know.
    Ruchir
  • Posted 20 February 2020, 1:34 pm EST
    Hi David,
    Please try the following code instead:
    doc.Body.ComplexFields.First.GetRange().Paragraphs.Last.GetRange().Tables.Insert(2, 2, InsertLocation.After);
    The reason is that a complex field’s range ends at the last run. A table cannot be added after a run, but only after a paragraph. Hence the error in your original code. Hopefully the modified code above will work, please let me know.
    Dmitry.
  • Posted 20 February 2020, 1:50 pm EST
    That works great. Thank you.
  • Posted 20 February 2020, 1:53 pm EST
    Excellent, thanks for the heads up!
