Output PDF not retaining Font styles from Word template
Posted by: grapecity on 11 July 2024, 11:22 am EST
    Posted 11 July 2024, 11:22 am EST
    I’m applying some Google fonts (ie. Noto Sans, Noto Serif) to content in my Word template. I’ve tried out some of the methods explained in https://developer.mescius.com/document-solutions/dot-net-word-api/docs/online/font.html but this seems to only work when I’m assigning the font to content that is programmatically added onto the template.
    In my implementation, there is no content that is added programmatically; I’m processing Word templates as is, but these additional fonts in my Word templates are getting stripped out. Is there a method or setting to keep these fonts in the output PDF?
  • Posted 17 July 2024, 7:43 am EST
    Apologize for the delay. You need to programmatically set the font on the Template text as per your requirement. Then you can process the Word Template to achieve your requirements.
    Please refer the attached sample for the same: EmbedFonts.zip
    Nitin
  • Posted 3 July 2025, 5:12 am EST
    Thanks for the response.
    What if the DsWord template has multiple font styles, will it still work? Can you also an example for the same?
    Also, Where can we get the list of fonts?
  • Posted 3 July 2025, 7:44 am EST
    Hi Vinay,
    Thank you for your follow-up.
    To avoid duplication and ensure consistent support, kindly continue this discussion on the private support portal where you’ve already raised this query. We’ll assist you further there.
    Kind Regards,
    Chirag Gupta
