Refreshing field values / table caption
Posted by: david.sheppard on 16 August 2023, 10:20 am EST
    Posted 16 August 2023, 10:20 am EST
    I am placing a caption with a SEQ field above tables in a document. For example:
    Table {SEQ * ARABIC}. table description
    Unfortunately, when I open the document in word the number won’t appear unless I select the entire document (ctrl+A) and refresh all the fields using the F9 key. For example the above code looks like:
    Table. table description
    instead of like
    Table 1. table description
    How can I get the caption numbers to appear when I open the word document
  • Posted 18 August 2023, 8:05 am EST
    Hi David,
    We are not sure how you are actually using SEQ Field with GcWord Library. Could you please share a small sample replicating this behavior? So, that we can investigate further and assist you accordingly.
    Also, SEQ field name is missing. Please try with below example:
    {SEQ myseq \* Arabic}
    Nitin
  • Posted 18 August 2023, 8:20 am EST
    Sorry. That was a typo in my post. Below is the code I am using.
    My word document has a mail merge field that defines the location of a table. I search through the document for complex fields and then insert a table, then the caption that goes above the table.
    Paragraph1 = ComplexField1.GetRange().Paragraphs.Insert("Table. “, InsertLocation.Before)
    Paragraph1.GetRange().ComplexFields.Add(“SEQ Table * ARABIC”, result:=TempString)
    Paragraph1.GetRange().Runs.Add(” " & Caption)
    Paragraph1.Format.Alignment = ParagraphAlignment.Center
  • Posted 21 August 2023, 5:24 am EST
    We have replicated this behavior at our end. This seems like a bug. So, we have escalated it to the development team. Will get back to you once we have any update from them.[Internal Tracking Id - DOC-5678]
    Nitin
  • Posted 22 August 2023, 12:54 am EST
    As per the development team,
    MS Word can show only the field result.
    Right now filling the field result is user’s responsibility.
    So the only way at this moment to fill the field result or use MS Word “Update fields” feature which writes the field result automatically.
    We apologize to inform you that currently this is a limitation which will be removed when a internal task to update the fields[Internal tracking Id - DOC-5138]
    is done, rather than ‘by design’.
    Nitin
