Replace simplefield with text
Posted by: david.sheppard on 20 May 2019, 10:19 am EST
    Posted 20 May 2019, 10:19 am EST
    I want to search through the document to find simplefields and replace the simplefield with text that my program generates. I can find the simplefields by looping through the document.body.sections. I can remove the simple fields by using the simplefield.delete method. How can I insert text where the simplefield was located?
  • Posted 21 May 2019, 3:24 am EST
    I am discussing your requirement with the concerned team [ID: 1234]. I’ll get back to you once we receive some information from them.
    Ruchir
  • Posted 21 May 2019, 7:54 am EST
    I was able to find and replace the simplefields using the following code.
    For Each DocSec1 In Doc1.Body.Sections
    DocSecRange1 = DocSec1.GetRange()
    For IndexField = 0 to DocSecRange1.SimpleFields.Count -1
    Field1 = DocSecRange1.SimpleFields(IndexField)
                FieldCode = Field1.Code.Trim
                DocSecRange1.Document.Body.GetPersistentRange(Field1.Start, Field1.End).Runs.Insert("AAA", InsertLocation.Before)
                Field1.Delete()
            Next
    Next
  • Posted 22 May 2019, 6:15 am EST
    Great that you could find a solution for your requirement.
    Also, thank you for sharing the solution, it would help other members as well over the community.
    Best wishes,
    Ruchir
