Create column of buttons in Flex Grid
Posted by: pablo on 9 November 2021, 5:11 am EST
    Posted 9 November 2021, 5:11 am EST
    I have a question related to the Flex Grid and the cell template. I’m trying to create a button in each cell from a column, with the aim of showing a view. I’ve already done it, however, I need to bind a different value from the model in each cell. To explain myself, I have a model defined in the view (where I’m creating the Flex Grid) like this:
     @model IEnumerable<C1MvcApplication1.Models.Clients>
    And the Flex Grid is defined in this way:
    <c1-flex-grid id="theFlexGrid"
                  auto-generate-columns="false"
                  is-read-only="true"
                  sorting-type="SingleColumn"
                  class="grid"
                  pinning-type="SingleColumn"
                  auto-search="true"
                  default-column-size="100"
                  default-row-size="47">
    <c1-flex-grid-column binding="clientCode" header="Code"></c1-flex-grid-column>
    <c1-flex-grid-column binding="clientName" header="Name" width="200"></c1-flex-grid-column>
    <c1-flex-grid-column is-read-only="false" align="center" width="70">
            <c1-flex-grid-cell-template>
                <a id="edit" asp-controller="clients" asp-action="Edit" class="btn btn-default" asp-route-clientCode="xxxx" style="background-color:none;"><img src="~/lib/icons/Edit.png" /></a>
            </c1-flex-grid-cell-template>
    <c1-items-source source-collection="@Model"></c1-items-source>
    </c1-flex-grid>
    In this example I have defined an asp-route-clientName with a single value “xxxx”. Nevertheless, what I’m trying to do is to define a value like “@Model.clientCode”. I know that’s something we can’t do with the type IEnumerable<> but I need a solution to select each value from this variable.
  • Posted 10 November 2021, 4:06 am EST
    Please refer to the following points for the resolution of the above query:
    • Instead of using an anchor tag, we may add a click event listener to the set template and may implement the following functionality in the handler.
    • To get the dataItem for the selected row, we may use the hitTest and dataItem property of FlexGrid Row, to get the required information.
    • After which we may redirect the user to the next view with the above information accordingly.
    Please refer to the sample below.
    FlexGrid.zip
    Dushyant Sharma
