Display multiautocomplete selected values in flexgrid cell
Posted by: 1728884346 on 15 October 2019, 9:13 am EST
  • Posted 15 October 2019, 9:13 am EST - Updated 29 September 2022, 10:49 am EST
    i get example from https://www.grapecity.com/forums/wijmo/display-multiautocomplete-
    refer to attached html, i update deafult flexgrid readonly to false, then it auto add some class to the flexgrid once select the cell. E.g. wj-state-readonly.
    is it expected behaviour?
  • Posted 15 October 2019, 9:14 am EST
    re-upload the html file in zip.
    FlexGrid_MultiAutoComplete_display1.zip
  • Posted 16 October 2019, 12:25 am EST
    The sample used the older build. The current build is 5.20192.631.
    In the latest build behavior is as follows:
    1. If isReadOnly is true - wj-state-readonly class is added to the host element
    2. If isReadOnly is false and CustomEditor is not added - wj-state-readonly is not added
    3. If isReadOnly is false and CustomEditor is added- wj-state-readonly class is added to hostElement.
      This might be to allow making selection/change for CustomEditor. However, we observed that this does not cause any issue.
    Manish Gupta
  • Posted 16 October 2019, 12:59 am EST - Updated 29 September 2022, 10:50 am EST
    thanks manish, one more question. refer to screen below, how i can bind itemsSourceAction instead of itemsSource?
    sometime it may has lots data, its good to only retrieve data when type something.
  • Posted 17 October 2019, 1:13 am EST
    You may add use the itemsSourceFunction instead of itemsSource same as for AutoComplete.
    Please refer to the attached demo sample and following documentation link:
    https://www.grapecity.com/wijmo/api/classes/wijmo_input.multiautocomplete.html#itemssourcefunction
    Manish Gupta
    FlexGrid_MultiAutoComplete_display-ItemsSourceFunction.zip
