Edit values in FlexGrid at run time
Posted by: chintu2691994 on 8 April 2019, 8:13 am EST
  • Posted 8 April 2019, 8:13 am EST
    I have made an HTML form with a FlexGrid. I want to add some values/rows with values in FlexGrid at runtime.
    Initially, the Grid will be all blank and will only set values if one of text boxes are filled with some values
  • Posted 9 April 2019, 7:28 am EST
    If we understand correctly, you have added a FlexGrid in the page with no data bound. Now, you would like to add the records in FlexGrid as the Form is submitted.
    Please confirm and if this is not the case, please elaborate your use-case so that we may assist you ahead.
    Manish Gupta
  • Posted 2 May 2019, 6:54 am EST
    thanks but found my way around the problem,
    I had to use ajax and then load that data on to FlexGrid.
  • Posted 6 May 2019, 1:51 am EST
    Thanks for letting know us that you have found a way to resolve your issue.
    Manish Gupta
