Posted 14 September 2017, 12:47 pm EST
How can i save current states for grid after reload page?
are there any examples?
Forums Home / ComponentOne / ASP.NET MVC Edition
Posted by: 048alexsandr1992 on 14 September 2017, 12:47 pm EST
Posted 18 September 2017, 10:18 am EST
What do you mean by state? FlexGrid is a bound grid and thus any state would be dependent upon its data. So if the items-source are changing, grid would change.
~nilay
Posted 19 September 2017, 3:46 am EST
I want save current filtering parameters, the visibility of the columns, the current page number after reload page. For example save this in session.
Posted 20 September 2017, 2:36 am EST
It can help in my question?
https://www.grapecity.com/en/forums/wijmo-archive/how-to-save-grid-column-or
Posted 25 September 2017, 9:33 am EST
As of now you have to store the FilterDefinition string at your end as a string and load them when Flexgrid is loaded. Columns definitions and other settings too are to be saved manually.
~nilay
Posted 26 September 2017, 5:29 am EST
How bind to event “on filter apply” on client side?
Posted 26 September 2017, 5:48 am EST
as I understand, string
var filter = new wijmo.grid.filter.FlexGridFilter(flex);
create new filter.
How can i get current filter with user changes?
Posted 27 September 2017, 12:48 am EST
You can use FlexGrid JS filter events:
var f = new wijmo.grid.filter.FlexGridFilter(flex);
filter.filterApplied.addHandler(function (s, e) {
filter.filterChanging.addHandler(function (s, e) {
filter.filterChanged.addHandler(function (s, e) {
For razor filters:
@(Html.C1().FlexGrid<Sale>()
.Id("ovFlexGrid")
.AutoGenerateColumns(true)
.Bind(Model)
.CssClass("grid")
.Filterable(f=>
f
.DefaultFilterType(FilterType.Both)
.OnClientFilterApplied("OnClientFilterApplied")
.OnClientFilterChanged("OnClientFilterChanged")
.OnClientFilterChanging("OnClientFilterChanging");
.OnClientSelectionChanged("csFlexGrid_SelectionChanged")
function OnClientFilterApplied(s, e){
function OnClientFilterChanged(s, e){
function OnClientFilterChanging(s, e){
~nilay
Posted 27 September 2017, 6:16 am EST
How change columns order on client side? This is necessary to save the column positions after Drag and Drop.
I tried to save filter conditions (use event OnClientFilterApplied) :
function saveFilterState(s, e) {
var gridName = $(s.grid.hostElement).attr(‘id’);
$.cookie(gridName + ‘_filter’, JSON.stringify(s._filters));
but get error
TypeError: Converting circular structure to JSON
How to save filter data correctly?
Posted 28 September 2017, 5:37 am EST
"columns": [
{"dataType":2,"binding":"ID","header":"ID"},
{"dataType":4,"binding":"Start","header":"Start","format":""},
{"dataType":4,"binding":"End","header":"End","format":""},
{"dataType":1,"binding":"Country","width":100,"header":"Country"},
{"dataType":1,"binding":"Product","header":"Product"},
{"dataType":1,"binding":"Color","header":"Color"},
{"dataType":2,"binding":"Amount","header":"Amount","format":"c"},
{"dataType":2,"binding":"Amount2","header":"Amount2","format":"c"},
{"dataType":2,"binding":"Discount","header":"Discount","format":"p0"},
{"dataType":3,"binding":"Active","header":"Active"}
This is serialised form of WjFlexGridColumn. The entire reference to which is provided here:
http://demos.wijmo.com/5/Angular/WijmoHelp/WijmoHelp/topic/wijmo.grid.Column.Class.html
You have to retrieve, manipulate and save columnLayout JSON like this:
var grid, layout;
c1.documentReady(function () {
grid = wijmo.Control.getControl("#ovFlexGrid");
layout = GetLayout();
function GetLayout(){
return grid.columnLayout;
function SetLayout(newLayout){
grid.columnLayout = newLayout;
Some tips:
Changing the order of JSON file would change column order.
var gridName = $(s.grid.hostElement).attr('id');
$.cookie(gridName + '_filter', JSON.stringify(s.filterDefinition));
~nilay
Posted 28 September 2017, 9:52 am EST
thanks!
Posted 14 December 2017, 2:48 pm EST
I have a similar requirement. I’m looking to save column widths, visible column selections, filters, sorting, and grid page for users. Then use the saved values next time the page is loaded. Is there a sample project that demonstrates how to do all of this?
