Flexgrid custom cell
Posted by: kisar on 13 August 2018, 4:40 am EST
    Posted 13 August 2018, 4:40 am EST
    Hi, i’m using flexgrid component
    could I have me some example how to create
    some custom template (razor):
    • padding, margin in row cells
    • padding, margin, font in header columns
    • using hmt code in row cells (image, ……)
    Thank you
  • Posted 14 August 2018, 4:51 am EST
    You may apply styling for cell by defining style using .wj-cell class and HTML content can be add to the cells using ItemFormatter property. Please refer to the attached sample and following code snippet for the same:
    <style>
        .custom .wj-cell{
            padding: 10px;
        .custom .wj-cell.wj-header {
            color: white;
            background: black;
            font-family: 'Times New Roman', Times, serif;
    </style>
    <script>
        function ItemFormatter(panel, r, c, cell) {
            if (panel.cellType == 1 && c==2) {
                cell.innerHTML = "<img src='https://images.pexels.com/photos/103567/pexels-photo-103567.jpeg?auto=compress&cs=tinysrgb&h=350' width=25 height=25 /> " + cell.innerText;
    </script>
        Html.C1().FlexGrid().Id("grid").CssClass("custom")
        .IsReadOnly(true)
        .Height(500)
        .ItemFormatter("ItemFormatter")
        .Bind(m => m.Bind(Model))
    Hope it helps!
    ~Manish
    FlexGridIntro_Cell_padding_ImageHTML.zip
  • Posted 14 August 2018, 5:34 am EST
    thank you, could you explain me when it’s better to use .CellTemplate(b => b.TemplateId(“template1”).
    In this case I have a grid column with a binding field “is_active”, in each rows if the value is true I display a image,
    in the classic html i used to do:
    @if (item.is_active)
    How is the easier way to obtain this?
  • Posted 16 August 2018, 4:48 am EST
    We are sorry for the delayed response.
    The ItemFormatter would be better to use. Please refer to the following code snippet:
            if (panel.cellType == 1 && panel.columns[c].binding=="is_active") {
                if(panel.rows[r].dataItem.is_active){
    		cell.innerHTML='<i class="fa fa-check text-primary" aria-hidden="true"></i>';
    ~Manish
  • Posted 16 August 2018, 10:37 am EST
    Thank you
    very usefull
