Flexgrid Printing
Posted by: matth on 22 October 2017, 7:01 pm EST
    Posted 22 October 2017, 7:01 pm EST
    Is there any samples showing how we can print flexgrids visible content? I.e. what is filtered? Including what is out of the scrolled window?
  • Posted 23 October 2017, 5:03 am EST
    Hi Matthew,
    You can export FlexGrid direct to PDF using PDF export, please refer to the http://demos.componentone.com/ASPNET/MVCExplorer/FlexGrid/PDFExport for the same.
    If you would like to show preview or direct print, you need to use PrintDocument class. Please refer to the http://jsfiddle.net/Wijmo5/c75xjs11/?utm_source=website&utm_medium=embed&utm_campaign=c75xjs11 for the same.
    ~Manish
  • Posted 23 October 2017, 5:10 pm EST
    Thank you so much, Manish!
    Is there a way to add/remove columns to the table before I render it or append it?
    Matt
  • Posted 24 October 2017, 7:05 am EST
    You can add/remove row/column from FlexGrid before render/adding FlexGrid. You can also skip any row or column by customizing renderTable method.
    ~Manish
  • Posted 24 October 2017, 4:28 pm EST
    I have figured this out! Thank you!
