FlexGrid use DisableServerRead or not
Posted by: 048alexsandr1992 on 15 March 2018, 6:12 am EST
    Posted 15 March 2018, 6:12 am EST
    I can not decide, use DisableServerRead good idea or not.
    For example, I have table with 1000 000 items.
    In FlexGrid I used many client-side operations: save states, quick search…
    http://demos.componentone.com/aspnet/ASPNetMVCCollectionView101
    If DisableServerRead = true, then table loaded about 1,5 minutes.
    If DisableServerRead = false, then my table loaded about 15 seconds.
    But some client-side operations require DisableServerRead = true,
    and also when i restore grid state with
    collectionView.sortDescriptions
    itemsSource.pageSize
    filter.filterDefinition
    each of them initiate request on server.
    That will be more correct?
  • Posted 15 March 2018, 6:35 am EST
    The problem is that there is a choice between long loading if DisableServerRead = true, or multiple requests to the server when restoring the saved state and refusing some functionality.
    Both choices are not very good
  • Posted 28 March 2018, 5:50 am EST
    Hi Alex,
    I get it. There are some unavoidable drawbacks of using multiple requests. For your case, I would suggest you use client side virtualization.
    See example here:
    http://jsfiddle.net/72cnp61c/7/
    ~nilay
  • Posted 18 April 2018, 1:42 am EST
    I compete my task by next solution.
    I use DisableServerRead = false.
    Grid state save in localStorage as before. But use special block
    flex.collectionView._disableServerRead = true;
    ... // restore state
    flex.collectionView._disableServerRead = false;
    flex.collectionView.refresh();
    In this way, when you restore a state, there will be only one request to the server.
  • Posted 20 April 2018, 4:23 pm EST
    very interesting post.this is my first-time visit here.I found so many interesting stuff in your blog especially its discussion…thanks for the post! http://delltechnicalsupportnumber.co.uk/ Thanks for your blog. Really wants to appreciate your work. I go through all points…
